706 Heads Rule?! (706 vs 241 vs 317 vs 799/243)
Yep, buy e-3 plugs, sponsored by dustless blasting.
Cant use ls9 gaskets on 706/806/862/853 heads that have notch on the deck or any other mls gasket save for pricey Felpro mls or Cometic mls. They use the ls9 because social media and the internet tells them to. Nevermind the horrible quench and cr drop the ls9 gaskets are BADASS and made for boost! Most of them dont even realize some heads have that notch in them.
We have a thread about em here
Pic on customer engine also
https://www.instagram.com/p/BcacNcBBQs2/
I personally would never do the LS9 on a 3.78 or even a sub4", but that's me. It appears to work, but I've seen wrenches work as hammers before as well.
LS1Tech Premium Sponsor
We have both gaskets for up to 3.910 bore and then another gasket for 4.065 bore.
Gm discontinued the graphite gaskets so the only option was still a flakey nasty aftermarket gasket until these.
Still quite a few early 4.8, 5.3, and 5.7s that have heads with a notch, but afaik no one offers an mls to use a set of notched heads on a 4" or larger bore but us. A few companies that cnc alot of 5.3 heads have bought them in bulk from us. Saves alot of time and extra cost in the head of welding up the notch and surfacing vs just buying a gasket.
Yep...for years the TSP 2.5 5.3's, MS3 cam, and Fast 90 was a proven 450whp/380wtq combo for a 346. I want to say TSP sold the heads cam package for around 15-1700.00.
I would of went with a different cam that brought the torque up around 400 even if peak power dropped to 435. However TSP probably sold thousands of the combo above.
For the money I'm very happy with my TSP 2.5/5.3 heads. My cam is almost identical to the MS3, and I'm running a Fast 92 as well. Whatever my top end lacks I more than make up with it with the 150 shot
706/862 is a diamond in the rough. In my opinion they are one the best cathedral port heads for a budget if you know what your doing. They will flow well into the 300’s at .600 lift without CNC porting.
When I was still in the head business I had a set of 706’s that I worked for my own setup. 5 angle valve job to 2.00/1.600 with a custom top cut, bowl blend, back cut the valves and a couple little minor things they did very impressive on the flow bench.
I believe I had a 3.900 bore fixture on, but they flowed around 310ish at .600 lift, I believe it started to get turbulent around .800 lift. Nothing really crazy done.
Most people don’t realize about 85% of your gains from porting is in the valve job and bowl blend. If you can handle a burr outside the 350-400 bucks you’ll have in machine work you’ll out perform a lot of aftermarket heads too. The goal is the most air though the smallest port...
Nice to see a real world comment on head work.
Ron
#32
WS6TECH, Online, you still have bit of an issue with ordering the right gaskets. I just recently bought a head/cam gasket set. In this set, I received the GM MLS gaskets for the later heads. I have the 853's. All that was listed was LS1 perimeter and LS1 center bolt. Of course I didn't realize there was an additional difference until I started matching things up. Then I had to order another set of the "blues", which I never even looked at after seeing the set that had everything I needed. You probably need some kind of questionnaire or additional drop down option with the gasket sets to insure correct gasket sets. Of course, Mike said I could return them, but I had already opened them and destroyed the packaging. I am not mad about it, because I caught it. I feel sorry for the fellas that don't.
I will be trying to add that option shortly. we are switching to a new site and its painful to say the least. Thank you for the input. If you didnt install the gaskets or scratch them, we can def take them back if you wanna send em.
I have notated EVERYWHERE on the notched gaskets they are for notched heads lol but doesn't help when they arent an option on the heads cam kits.
#34
So im a newbie in the cylinder heads area. Lets say you have both the 706 heads and the 243 heads and you want to get them milled or ported, which ones would you do after seeing this? dont know if this helps because i know there are a bunch of different ways at working on the heads, but i was looking at spending around $400 to $500.
#35
I have found a number of inconsistency in the test from what I can see . Ill point out a just a couple . First the 706 flow numbers.... these must be factory freaks because the 5.3 heads that I have flowed are in 220s and climb very little after .500 .But the ones in test jump 11 cfm alone from .500 to .600 and peak at 237. At first I thought this is just a very generous flow bench , but thats not consistent either . Because the numbers for the 317 seem to be pretty much on par. And I can accept the 799 numbers being low . Here is why the 799 can have some core shift that will create insert overhang in the bowl. this may explain them being approx 10 cfm off. A 243 should flow in the 250s .This test has a 17 cfm difference @ .600 between the two. Do another test 706 vs 243 there should be 30 cfm difference between to two.
#37
I like to look at low-lift flows to see how efficient they are. THEN I see if it carries thru the higher lifts. If solid flow improvements are seen at all lift levels, it's a good head in my book.
#39
#40
