Critique my build
I have a full mamo top end to go along with the new set up, probably not the best options but it's gonna have to do for now
Future plans
Texas speed 408 with compression around 11.1
Mamo 220 heads,
Johnson lifters
Ati balancer Mamo spec
Mamo ported msd atomic
Nw 102 tb
All this running through a t56 and a mwc 9"
I'm a bit undecided on the cam itself
What would be a good choice ?
Looking for a street/strip more or less
Above 500, that was the route I was aiming for with the ls1. Don't care about sound lol I want performance
Looking through phone so i can't see sticky's
Here it s a post you might like, this guy is making real good power. His cam numbers are in there a little ways down. Its a pretty big cam
I used his AFR heads in the past, and wanted a stealth like cam, favoring torque. Tony hooked me up with the perfect daily driver cam for what I wanted.
What et/trap you trying to run?
I want to get into the 10s or low 11s
Running 10s will nit be a issue. You might even put some cash back in your pocket.
check out Dyno results P2 MMS 223 Sportsmen Heads 416"
made 528rwhp/515lb' with 237/244 114+2.
your 220 heads are more exhaust efficient
something like 239/245 114+3 should put
you over 500 rwhp with all the fixins,
true duals, ewp, efficient driveline.
would make a very nice street/strip combo.
LS3 combos can/will make more, its only money LOL,
how much power do you want or need?
But realistically I'm shooting for 520
I'll be getting the Mamo 235s eventually
