422 high compression & spark plug gap?
Old 07-03-2004, 10:19 AM
Brian C's Avatar
Default 422 high compression & spark plug gap?
Just wondering what spark plug gap is being used on high compression 422 cu in LS1's. Trying to track down a loss of power at high rpm's in a friend's car.
Thanks,
Brian
Old 07-03-2004, 03:08 PM
strokedls1's Avatar
I use .039 gap with 11.2-1 on a iron 422 with a 100 NX wet shot. 28 degrees of timing with no knock retard. NGK TR6 plugs.
Old 07-03-2004, 05:00 PM
TApimp's Avatar
what compression ratio is it?
u may be able to run an NGK 5671A-7 or -8 in it
Old 07-04-2004, 08:48 AM
Brian C's Avatar
It's about 12.5:1, no nitrous.
Thanks for the replys,
Brian
Old 07-04-2004, 01:44 PM
Nickn20's Avatar
Try a TR6 @ at the factory .035 gap.
