Notices
Anyone still use sloppy stage II?
Old 03-09-2018, 08:50 PM
Originally Posted by Kawabuggy View Post
I recently installed the E1839P cam into my LQ9. The operating range is definitely a misprint. That cam pulls right off idle, all the way through 6K easily.
This cam has a great rumble at idle. It is making MORE power-EVERYWHERE-over the LS9 cam (on a 115.5 LSA) that I pulled out.
I debated on going with the E1840P but was dissuaded from doing so by wise people on this forum. I'm glad I followed that good advise. The -39 cam sounds and runs great.
Did you change pushrods? If so what length did you use? Don't recall if the LS9 cam has same base circle size as the Elgin. The Elgin has a 0.050 smaller RADIUS than stock LQ4/LQ9. I fired mine up a few days ago with the stock pushrods and agree the sound is great.
slarsen47 is offline
Old 03-11-2018, 10:18 PM
I'm running factory length 7.4" push rods. I used an adjustable push rod checker and it came out that I needed a 7.390" length. I just ran the factory length, and it is nice and quiet. However, I also have milled heads, and .041" Cometic head gaskets, and LS7 lifters.
Kawabuggy is offline
Old 03-12-2018, 08:25 AM
Thanks for info. I have read in several places that OEM GM pushrods are actually 7.385 but that most people refer to them as 7.4
Old 03-12-2018, 10:42 AM
We just paid for these using the 20% off sale they had going last weekend... Also got some pac1218 springs to go in too. Budget boosting baby!!
I bought one too even though I am not doing a build right now lol
Last edited by KCS; 03-13-2018 at 04:38 PM. Reason: Non Sponsor Pricing Info Removed
Suncc49 is offline
Old 03-12-2018, 01:09 PM
Bspeck82's Avatar
Idk guys, Risking an engine to possibly cheap Chinese steel of unknown origin with incredibly lazy lobe design? If it was a cheap beater than yes I would swing for a cam like this, but I wouldn't want that cam anywhere near my engine. If it's a car you care about then do it right or leave it alone. Just my .02 I guess. Not hating on anyone's decision, purely an opinion.
Bspeck82 is offline
Old 03-12-2018, 01:36 PM
So purely speculation on your part eh? There are only a few big international companies out there that grind cams for the big boys. If that makes you sleep better at night go for it and spend tons of $$$, but speculating on the "cheapness" of material is silly.
Suncc49 is offline
Old 03-12-2018, 02:14 PM
Not sure if what you say about lazy lobe design is accurate, but a lazy lobe design is a good idea unless you are building an all out race engine. A lot easier on parts in a dual purpose street/strip car.
I accept your opinion for what it is..........just an opinion without any facts to support it.
As a matter of fact I am seriously thinking of putting the Elgin 216/220 in my stock 5.3 cruiser. Works with cheap made in Mexico blue valve springs......lol
Old 03-12-2018, 05:08 PM
LS9 cam ? ....... oem LS9 lsa 122.5 not 115.5 lsa
omc8 is offline
Old 03-12-2018, 08:09 PM
A.R. Shale Targa's Avatar
FWIW Elgin is a giant company that has HUGE production runs which allow cheap pricing. And while the lobe “know it alls” may giggle at the specs, ramp rates, lift, etc. I’ve never had one fail. I’ve used at least a hundred Gen I flat tappets in Street hydraulic SBC and solid lifter stock car engines. All ran well and did what they were intended for.
A.R. Shale Targa is offline
Old 03-12-2018, 08:10 PM
Please note that is why I put the 115 in parenthesis. The Howards version uses a tighter LSA for a NON super-charged version. It is a "torque" cam for all intent and purposes. Designed for off-idle to about 5500 ONLY. Right where my factory LS2 intake seems to fall off anyways if you can believe all of the dyno reports.
Old 03-13-2018, 03:24 PM
Do you have a link for that Howards Cam ?
omc8 is offline
Old 03-13-2018, 04:42 PM
  #32
KCS
Moderator
KCS's Avatar
Some of you need to read the Non-Sponsor Soliciting Policy. It's okay to discuss products made or sold by vendors that do not support this site, but do not post contact or pricing info. It's unfair to the vendors that do pay for this site.
KCS is offline
Old 03-13-2018, 06:59 PM
  #33
Restricted User
If JEGS and Summit are OK with putting their brands on them, then they are fine.
The Lobes on the 228/230 cam are similar to the BTR Stage 2 Truck cam in aggressiveness (the truck cams have the mildest lobes of the BTR cams).
JoeNova is offline
Old 03-16-2018, 09:46 AM
  #34
Is Summit still a sponsor here , they are still on the list ?
omc8 is offline
Old 03-16-2018, 09:53 AM
  #35
Restricted User
As far as I know they are. I still post links to products on their site here fairly often.
JoeNova is offline
Old 03-18-2018, 09:49 PM
  #36
07V
I'm running that cam and I dig it a lot. It's basically the sloppy build, part for part. 4.8, sloppy stage II cam, 76 china turbo, p01 2 bar flex, decapped injectors, Wally 450. I specifically copied his build because I wanted to tune it myself. Little did I know, that's not how tuning works. I bought HPtuners and tuned for that cam and built trans/stall first, then once I got the hang of tuning I did the turbo. The cam was a breeze to tune, and overall, everything went great. I have no idea how much power I make since I tuned it on the street myself, but most people I talk to think that at 16#, 18* advance (on corn), 4.8 with a 76 I should be in the low-mid 500s rwhp.
07V is offline
Old 03-18-2018, 10:24 PM
  #37
kingtal0n's Avatar
All I want to know is,
is there any other cam provided by Jegs,
with the same duration,
but even slower more gentle ramps and less lift?
kingtal0n is offline
Old 03-18-2018, 10:43 PM
  #38
07V
That seems like a fantastic question for the sales reps at jegs. If you go to their website, and go to “contact us,” there’s a phone number listed. Call that number, and ask them the exact same question you asked here, and they’ll give you a laundry list of cams you’d be interested in.
07V is offline
Old 03-19-2018, 06:19 AM
  #39
Restricted User
Comp offers one in the same duration with less lift, but I think the lobe profiles aren't any softer.
JoeNova is offline
Old 03-19-2018, 04:34 PM
  #40
kingtal0n's Avatar
haha. Well with everything I've read lately I would go Jegs > Comp
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
