BTR TFS 220's EPS Cam... WHOOPS!
#142
Nice, sounded angry when you fired it.
Sounds like an exhaust leak to me, videos do change things, but it still sounded pretty clear, and just like an exh leak IMO.
I use a mechanics stethoscope to find exhaust leaks, pull the end of it off leaving just the rubber hose and stick a metal brake line in the hose then bend the end so you can get up under the manifold. Trace all flanges with it and you'll find your leak and pinpoint it.
Now a new noise has started. Once the car gets hot there is a noticable hum towards the back of the intake manifold. Has anyone heard that? I'm wondering if there is a leak there somewhere...
#143
The mechanics stethoscope was genius! I took the end of and probed around the header and found the leak at the air injection blocking plate. Really cool way to use that thing!
It's been an awesome tool for me and I randomly came up with it one day. BTW, I also use it for vacuum leaks and it works great. Try that around the intake, a hum is usually a leak.
I figured it was an exhaust leak because the sound had an off beat rhythm, exhaust leaks do that, lifters usually have a very consistent rhythm and pulleys too. Glad you found it. Now check all injector o rings and the intake flange with the stethoscope. Beats spraying your new setup with brake cleaner.
Unfortunately you can't really get to the intake gaskets but you can maybe pick something up running it along the intake to head.
#144
#145
I thought I'd check the torque on the intake manifold bolts since it's been through a few heat cycles since I installed it. There were 3-4 that we're very loose, so I'm hoping that was the cause of the potential leak. It had to have been small because there was no weird map pressures or need for crazy VE figures. I'll update the thread with my results after the next start-up.
#146
Well, the saga continues. I tightened the manifold back up and the sound may have improved, but it's still there. Unfortunately I found another potentially more pressing issue. I polished up the headers a bit while they were out of the car, and I noticed that the driver side has already gone back to looking like it did before. The passenger side, however, is still shiny. I decided to grab my IR gun and measure the temperature of each header tube. The driver side tubes were all in the low-to-mid 400 degree range at idle, cylinder number two on the passenger side front was only 215 degrees, and the other tubes on that side were all roughly 50 degrees less than the driver side. I'm guessing the main temperature difference is due to the fact that the left side may be leaner than the right and is burning hotter, but something is definitely not right with number 2. Now I have to find out why it's not firing as it should. Yippee!
#147
#148
Sweet glad it's helping.
I would just pull the manifold off and inspect everything. I know it's a pain but it's worth a look.
When you put the manifold back on (this is what I do anyway) start in the middle and tighten the middle bolts first then work outward just like the head gaskets. Snug the middle ones tight with a 1/4" ratchet, so that you're applying roughly 15-20 ft lbs then the two bolts on each side of the middle and work outward. Hope that helps and hope you find it.
#150
I couldn't find anything obvious after removing the manifold. The fact that the sound only starts after it gets hot makes me feel like it's very minor. I left the metal locators in because I didn't think it was causing an issue, but I'll remove them to be safe. I also decided that I didn't like the off brand seals that I put in, so I'm going to order the ones from FAST. I'll follow back up after everything is reinstalled.
#152
Originally Posted by Mike Morris
Does car have any codes? Make sure you torque down those bolts and in order on the intake. I know its a pita under the coil. Even just getting to the fuel rail back bolts is a PITA with a FAST 102
#154
To test for spark grab a test light and hook the clip to the battery ground, with the engine running pull a plug wire off the coil or plug while holding the end of the test light real close to whatever you pulled the wire off of, the spark will jump to the end of the test light tip instead of your finger, and you should be able to pull the test light back about an inch before the spark stops jumping.
It should be a loud pop and bright blue. If it's yellow and only shoots off the coil about 1/4" you need a new coil.
I loosen all the wires and have them barely sitting on the coil when I do this makes it easy to run through and check all 8 real quick
#155
I will start the car again tomorrow to check on my multiple leak repairs. I resealed the air injection opening on the headers. Really wish they were off road headers. I also found that the intake was leaking at the head surface and in between the upper and lower shells in the passenger back corner. I took it apart and found that I'd forgotten to add the rtv in that area.
I was pretty shocked at how much oil was already in the intake. It hadn't been driven much, and very light throttle at that, yet there was a good coating all over the inside. I hadn't installed the catch can yet, but did that today after reassembling everything.
I'm going to give the rtv a day to cure and will attempt to start it up to check my work tomorrow. Wish me luck!
#157
Good news! Both leaks are fixed and it also remedied the cold header primaries. She is officially ready to tune. Base tune is doing okay, but I'm going to use a local tuner to dial it in and handle the WOT stuff on a loaded Mustang dunno. I'm hoping he'll get me in within a week or two. I'll definitely post the results when I have them.
#159
