Oil shavings on dipstick on new rebuilt engine
Has anyone seen oil shavings like this on a new engine?
Rebuilt LS1. Has run for maybe 10miles, 10296 Melling oil pump. Engine is nice and quiet, sees 40 + psi pressure at idle (20w50). Just noticed when checking the oil these shavings on the dipstick!, Dumped the oil, oil still looks new, can't see any metal at all in the oil.
Any ideas what this could be from?
I’d cut the oil filter apart and inspect before I started it back up. Maybe, hopefully this debris wasn’t cleaned off during rebuild? Your filter will tell you exactly what’s going on.
Wouldn't be surprised if it's debris from machining and you may find a little more.
And if you find some metal in the filter, put another on it and run it a little more and see if it continues to dump metal or if it stops. If it stops, cool. If not, you know you need look inside the motor.
I got a new to me truck in January and changed the trans fluid and filter, I cut open the filter and there was a decent amount of metal in there, and the trans is perfect 8 months and almost 10k miles later, however I'm sure that metal has been there a LONG time, it was the original factory filter. In other words, a little metal after a fresh build doesn't always mean it's shot to ****, may be nothing to worry about at all.
I've got my fingers crossed, will cut the filter open tonight after work and post up some pictures
Reason for the 20w50 was it's an E85 car, I have a Subaru that runs E85 also and always found it thinned the oil out so didn't want to go too thin. Will try a 10w40 this time.
Never heard of e85 thinning out oil, my guess is it's running too rich and fuel is getting into the oil and diluting it, which a thicker viscosity wont protect against dilution. Or it's not actually thinning out and just appears to be.
I don't know everything so there could be something out there with this, but if it were true, we should see engines burning up all over the place and strict warnings for cars that run e85.
Or e85 would cease to be available because companies would get tired of paying for peoples engines.
What kind of metal is it?
It looks like an edge or corner of something got shaved off by something harder scraping against it. Probably during the build but might have been during 1st startup.
E85 doesn't thin oil. Otherwise factory cars set up for it wouldn't tell buyers to use 5W-30 or whatever, same as if they use E10 or other normal pump gas. Put normal oil in it. Your Sube probably had bad rings and fuel washed into the oil... would have done the same thing with race gas, pump regular, av gas, or whatever.
The car is turbo, never had any issues with thinning of the oil at all with the Subaru when it was on pump gas, but as soon as the switch to e85 was done noticed it on the first oil change
