oil coming out of throttle body?
im doing an overhaul on a LS1 i bought that was picked out of a 02 WS6. had really low miles, 45k on the cluster and it's pretty damn clean.
last night i had the motor on my picker and it was resting on a tire leaning forward because i was replacing the pilot bearing and rear main seal. and i noticed oil was leaking out of the throttle body.
is this normal? or do i need to take apart the intake manifold too see what's going on?
No way for it to happen with the vally cover these engines have. Pcv in these cars aren't great, coats the intake manifold. Probably just seeing residual oil collecting and coming out.
Good reason to get a catch can.
The answer to your question is yes you will have to go through everything and thoroughly clean. You are seeing first hand the results of PCV as it has gummed up the throttle body, intake manifold, combustion chambers and the valves in the cylinder heads.
oh cool. thanks for the replies. The engine is 100% stock. no aftermarket plumbing or hose routed other than from the factory.
i already plan on running a PCV catch can so that should do it then. thanks for the input guys.
loving the new chapter in my cars life which will have the LS motor in a few weeks.
you guys are a lot friendlier and mature than the forum i had to previously deal with.
