Anyone running trick flow track max cam
So I'm wondering what length pushrods ppl have used with the Trick Flow Track Max .585 lift cam... I might snag one to upgrade from ls6 cam, but I don't want the car down longer than needed. I want to be able to swap everything over quick.
Thanks in advance
Thanks in advance
I would bet if you call Trick Flow they might tell you if the pushrod length needs changing.
