Mavns Summit cam build. Just made 450+ rwhp.. Stage 2 cam aka the Tire Puller...
#621
LS1Tech Sponsor
Received 1,121 Likes
Did you start with 61cc 5.3 heads? We see those are tighter...then the milling and the larger 2.04 O.D. valve all stack up. Our LS3 specific stage 3 and 4 cams use lobe offset on the intakes to give us a bit more clearance than the standard 3 and 4.
#622
Just ordered the Stage 2 turbo cam 226/230 for my 06 Silverado. 5.3 w/ cnc'd 241s and single 76/75. Current cam is the tick stage 2 turbo truck cam 219/223. We'll see how this one works. Thought about the ghost cam but i'm ready for the truck to sound a little nasty. lot of good reading here, thanks.
#623
Mav, did you get the picture I sent of the white birds reciever hitch setup on facebook. I also take it the shop that built the trans is the one garret and them uses. If so ima take this spare 4l60e I have and take it to them. Now just need to line out a torque arm, cross member, and some rear suspension. I think I can get the car to possible a low 11 on motor after looking at your build here.
#625
#626
#631
Zoinks!!! That is moving out. A well sorted combo. Efficiency at its best.
#636
I love that launch picture.
#639
