Which oil pump lq9 498 Im having a debate of which oil pump to run.. its going into a lq9 tsp 408 im rebuilding... i cant recall which one i used before as i know longer have it... my boy says go with the 10295 and i hear other people say go with the 10296.. or can i run a ported ls6? |
What are your bearing clearances? |
Originally Posted by xdanny510x
(Post 20005973)
Originally Posted by KCS
(Post 20005975)
What oil pump was in it before? Sounds like you’ll likely be good to go with the 10295 HP or ported LS6 pump. Stay away from the HV 10296 unless you need it due to loose bearing clearances and/or retrofitting piston oil squirters. |
Originally Posted by s30.hybrid
(Post 20006006)
© 2024 MH Sub I, LLC dba Internet Brands
