destroked 5.7 with 4.8 crank and rods - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Old 12-31-2018, 09:53 AM
Default destroked 5.7 with 4.8 crank and rods
Hey everybody was just wondering if I could use a 4. 8 crank and rods in a 5. 7 LS1 block with the 5. 7 Pistons
Louj3112 is offline
Old 12-31-2018, 10:35 AM
KCS
Moderator
KCS's Avatar
As long as you don’t use floating pin rods with pistons specifically designed for a press pin only, then you should be good.
KCS is offline
Old 12-31-2018, 10:38 AM
If I remember the math doesn't work out quite right. I ended up getting 6.3 rods and having custom pistons made to make my long rod motor.
TurboTim is online now
Old 12-31-2018, 11:10 AM
Well the math works just fine. 4.8 Rods and crank can be matched with any 5.3/5.7/6.0/6.2 as long as you use pressed with pressed and floating with floating.
MY_2K_Z is offline
Old 01-04-2019, 12:51 AM
Originally Posted by KCS View Post
As long as you donít use floating pin rods with pistons specifically designed for a press pin only, then you should be good.
Thanks yeah I got press in pins and Pistons ....
Louj3112 is offline
Old 01-08-2019, 03:03 PM
Any update on this. Sounds awesome
jdwtx85 is offline
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
