LS1 Hot Cam Question Hey guys, I am going to be putting a Hot cam in my 02z28 over the winter. I'm wondering if I should upgrade my fuel injectors and pump as well or will I be fine with the stock ones and the tune, anyone done this before or have any info on what the factory parts can handle? Thanks in advanced. |
It would be wise to upgrade to GTP injectors and a 255 lph pump |
Need something to support 1000hp. If you believe it's all in good working order, stock everything is fine for a hotcam. You should have bolt ons, and most go a heat range cooler on the spark plugs |
© 2024 MH Sub I, LLC dba Internet Brands
