Thoughts on new build plan ideas with fed stg 1 ls3 heads Well im 90% sure the used prc 237 heads I just bought are going back to the seller. After being disappointed on them in my other thread, they now cc’d a bit less than I was shooting for. I can play with the head gasket some, but not sure I want to lose all my quench. Considering jumping to square port after reading up on them. Plan would be the Frankenstein stg1 ls3 heads, fast 102 with medium runners, 90mm tb, 1 7/8 kooks, 238/252 114+3 620/622, 405 cubes (4.015 bore, 4 stroke), Johnson 2126 lifters, 3/8 pushrods. With an ivc of 49.8, being a stroker motor, and the medium length runners my math is looking @6800-7000 peak. my next bottleneck will obviously be the tb and 85mm maf, followed closely by the 2.5” ti mufflers. Depending on how bad they hold me back, I’ll be looking into upgrading there as well. Possible to still see 500tq? |
Possible, but it means everything will have to be perfect. It will not be a layup |
What will your compression ratio be? |
Originally Posted by KCS
(Post 20024486)
What will your compression ratio be? the ls3’s I can mill to whatever, but ideally 11.75ish |
(Post 20024482)
I’m calculating my dcr with the prc heads to be 8.65-8.8 thats a quench range from .044 to .038 |
I like your plan. Few things to consider, I would use AFR LS3 Heads out of the box with lighter valves & appropriate springs for your set up they will out perform the OE ported heads everywhere for your application and only need 8-12* exhaust split so 238/246- 238/250 would be ideal. For reference I have a all Bore 396" (4.175 X 3.60" Stroke) 11.7:1 Tony Mamo MMS LS3 TFS Heads with a LLSR 243/249 (Hydraulic Roller equivalent 237/243 115+3) adjusted for Lash. MMS Fast LS3 with Mid Length Peak @ 690 Flywheel HP Engine Dyno from 7100-7300 & carry to 7600+ With 1 7/8 LTs. Your 4" Stroke would pull everything down 300-500 RPM roughly. Mine is for a C5 also. |
OP If going with a 102 TB, why not ditch the 85mm MAF for a 100mm MAF or go Speed Density? |
(Post 20024533)
(Post 20024533)
Originally Posted by bthomas
(Post 20024494)
if I stay with the prc heads I’ll be 12-12.2 the ls3’s I can mill to whatever, but ideally 11.75ish |
Sell MAf for $80. Buy $10 4" Tube. Go speed Density.. Profit? |
© 2024 MH Sub I, LLC dba Internet Brands
