PTV clearance with tick sns stage 2
Anyone run this combo and had any PTV issues? I'll measure soon enough but was just wondering.
-Stock bottom end LS1.
-62cc 799 Stage 1 TSP heads
-Tick SNS stage 2 227/235 | .618"/.605" 110+3
- 0.041" Fel pro gaskets.
I think you'll be just fine but for s&g's get some putty on a piston and torque a head down and see what you got!
Check PtV this way
https://ls1tech.com/forums/generatio...ve-method.html
Check PtV this way
ya, I find it so much easier than dealing with clay on the piston then pulling the heads on, off, on, off trying to get a good mark then having to pull the clay off the cylinder cleanly.
Before doing it this way I just about lost my **** and threw the cylinder head through the windshield lol
I dunno what the hell I was doing before but I used a dial indicator this time with a checker spring and got significantly more clearance, which made more sense as my valves were sunk in with the valve job.
