4.10 .055 thick vs. 4.080 .051 thick head gaskets I have a 6.0L iron block bored to .030 and will use 243's heads with Diamond racing flat topped pistons. I wont be using turbos, just a mild cam, so which head gasket would be better? |
Originally Posted by Mike Cordero
(Post 20097890)
↑↑↑↑ This will give you more compression which is your friend in an NA application ↑↑↑ |
(Post 20097982)
4.08 bore |
© 2024 MH Sub I, LLC dba Internet Brands
