Notices
My Cam Only LS6 Project - Pic Heavy
Old 06-10-2019, 07:18 PM
Default My Cam Only LS6 Project - Pic Heavy
So basically i was on a mission with my bolt-on only ls6 powered 99 z28 to hit 10.50s or better but that came to a hault a couple weeks ago on my way to work when i heard a loud chirping noise coming from under the hood (i hate ls7 lifters). Long story short i pulled the motor apart and found two bad rollers and two cam lobes wiped out. I could of went with another ls6 cam and continued on my quest but after a lot of thinking i decided to go with something close to max effort. I dont want to disclose what i went with it but drivability was on my agenda so with that being said i could have gone bigger. So now the new quest is to see how quick this car will go cam only. My plans are to get the race weight down to 30XX lbs from 3270 previously and to do a couple more bolt ons i havent got to yet. Anyways here are pics from the project. I just got the cam out today, tomorrow i will start putting it back together.
SLP IROC-Z is offline
Old 06-10-2019, 09:44 PM
Tuskyz28's Avatar
Watching this one....
Tuskyz28 is offline
Old 06-10-2019, 10:03 PM
10 sec slip best et & mph with the stock ls6 cam
Old 06-10-2019, 10:21 PM
Tuskyz28's Avatar
I remember seeing the laungh photo in the fastest M6 list thread. Cool car and build.
Tuskyz28 is offline
Old 06-10-2019, 10:36 PM
Thank you! the ls6 topend is a great setup, great fuel mileage power and obviously stock drivability and it can be had cheap.
Old 06-10-2019, 11:57 PM
NSFW's Avatar
What are the specs on the new cam?
NSFW is offline
Old 06-11-2019, 12:07 AM
1988montecarloss's Avatar
I love seeing cars that do a lot with a little
stock compression ratio? Any portwork done to the heads?
1988montecarloss is offline
Old 06-11-2019, 04:39 AM
fst100's Avatar
nice results on that setup! makes me hesitate on picking up a set of low mileage ls7 lifters now.....
fst100 is offline
Old 06-11-2019, 06:16 AM
Are those .030 gaskets? :O
Bad346 is offline
Old 06-11-2019, 06:19 AM
trilkb's Avatar
This is a stock ls6 with cam, bolt ons, intake, gears and slicks?
trilkb is offline
Old 06-11-2019, 07:39 AM
No head work. The new compression ratio will be like 10.6/10.7, i had the heads cut to 62cc. Bought cometic .030s but not going to run them, going with stock mls instead.
Old 06-11-2019, 07:44 AM
i wouldnt buy used. If you can pick up a set of johnson drop ins.
yeah, i am not using them however, going with stock mls gaskets.
Yes. It went 10.8 @ 125 with the stock ls6 cam, hoping to pickup a few mph/ et with the cam upgrade.
Old 06-11-2019, 11:24 AM
What valvespring and how high do you spin it?
Old 06-11-2019, 11:40 AM
fst100's Avatar
too late lol.
fst100 is offline
Old 06-11-2019, 12:30 PM
PAC1211X springs, yella terra 1.8 rrs, lift was like .585 with the ls6 cam and 1.8s. Rev limiter is at 7200 i shift it at 68-6900. Now .660 tsp/pac springs, going back to 1.7 rockers
Old 06-11-2019, 12:46 PM
trilkb's Avatar
I'm just massively confused with how it's going 10.8s at 125 when a stock one doesn't get near that lol.
Spill the beans. Got a build thread?
trilkb is offline
Old 06-11-2019, 01:11 PM
Stock LS6 crate motor
FAST 102/102
Speed density tuned by me
FTP 104mm lid
SLP 25% under drive balancer
Yella terra 1.8 roller rockers
PAC 1211X springs
1 7/8 TSP long tubes ory borla catback
MSD wires
NGK TR55IX
Meziere EWP
LS7 injectors
SLP cold air
Cars a 6 speed. Race weight 3270. There isnt much to it. Im also not the only one whos gone 10a with an ls6 4th gen.
Old 06-11-2019, 05:23 PM
Put together a base tune... First pic is my ve table with the ls6 cam. Second is the ve table im going to use to start off with.
Old 06-12-2019, 07:46 AM
trilkb's Avatar
Wasnt saying you are not running 10's, just wanted to know the whole setup. I guess ls6 are just that much better than ls1's. I was blown away when I raced a c5z at the track and it trapped 120 or 118 out of no where it seemed. but he only went low 12's. Game of traction I guess, that rear end makes or breaks the engine getting power safely to the ground. And actually Mavns build proved it can happen with the right converter, but you both still have upgraded rear ends to get the most of it.
trilkb is offline
Old 06-12-2019, 08:48 AM
ddnspider's Avatar
Notice the race weight? Stock Fbodys with driver are significantly heavier. It's basically a max effort "stock" long block.
ddnspider is offline
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
