PRC 220 Heads?
Old Oct 9, 2019 | 10:33 AM
whatsa347's Avatar
Default PRC 220 Heads?
Did TSP come out with a 220cc as cast head and just go under the radar with it? I was browsing their site last night and came across these and can't find anything about them. Has anyone heard anything about them??
Old Oct 9, 2019 | 11:05 AM
00pooterSS's Avatar
No link bro
And not that I'm aware of. That I am aware of they have a 225 and 227
Old Oct 9, 2019 | 11:08 AM
whatsa347's Avatar
https://www.texas-speed.com/p-7753-p...ral-heads.aspx
They have an as cast version and CNC version, is this like an as cast 215cc head they used to offer? God I hope so.
Old Oct 9, 2019 | 11:25 AM
00pooterSS's Avatar
Very cool, didn't know they had those. Didn't see where it said as cast unless the as cast is a different listing on their website
Old Oct 9, 2019 | 11:30 AM
Bob570's Avatar
He used the wrong link, here's the as cast version.
https://www.texas-speed.com/p-7761-p...ral-heads.aspx
I was actually wondering about these a well. In my last thread I was asking about ported 243s and the consensus was to go with an as cast aftermarket head (probably TFS 220s) however no one mentioned these ever, I tried to find out as much as I could about them but didn't come up with much. If anyone has any experience about them I'd like to hear it.
If you opt out of the spring kit they're only $1450.
Old Oct 9, 2019 | 11:45 AM
00pooterSS's Avatar
I was the one that recommended the trick flows in your post.
I don't know about these. All I know is I have had a phenomenal experience with the TFS 220's and they cam at a recommendation from my tuner/builder who is one of the best that's ever been. And he knew of them from using them and the results from them
But with all the R&D and testing texas speed does theres no reason to believe the 220s wont be an excellent head. I would have a hard time choosing between the two, but would lean toward the TFS only because of using them before and being so happy with them.
Old Oct 9, 2019 | 11:51 AM
LaBLKv6Z's Avatar
Looks like they came out back in 2012.
https://ls1tech.com/forums/generatio...ds-inside.html
Old Oct 9, 2019 | 11:55 AM
whatsa347's Avatar
I didn't use the wrong link, I just linked the CNC ones I talked about as well. They both seem like good options, a 220 head would rip on an LS2.
Old Oct 9, 2019 | 11:57 AM
whatsa347's Avatar
I think those were the pre-cursors to the 225 they have now but these are new on their site, they had the "Terminator" 220 heads way back when as well but these seem to be different to both of those.
Old Oct 9, 2019 | 01:33 PM
mintws6's Avatar
If you look at the mid lift flow data for both Texas speed and Trick Flow you can see why people like the trick flow heads. Having great flow at Max lift is not everything. That being said I'm sure Texas speed has made a good head, I personally went with the TFS heads because BTR had them and offered the valve/bowl blending service. So it was an easy 1 stop shop that I could bolt right on and go. I really like BTR, service is good and the are helpful. I wish I had some knowledge in regard to the Texas speed heads...… I did have Texas Speed grind my cam though and it was spot on. Cars are fun!!
Old Oct 9, 2019 | 02:01 PM
Bob570's Avatar
I will likely go the route unless I find a great deal on used aftermarket heads. There just isn't a lot of information out there on the TSP 220s.
Old Oct 9, 2019 | 05:03 PM
00pooterSS's Avatar
Exactly. flow at max lift is almost useless as a single comparison item, well.. it doesn't tell enough of the story.
I'll dig around for the test that really shows it.. trying to remember the title of it right now
Here: http://www.superchevy.com/how-to/ght...s-head-to-head
Cathedral vs Rectangle. so that's a bit off topic but to get to the point. Cathedral head flows 338 cfm on the intake, the rectangle LS3 head flowed 372. Both are Mast heads. Both are 11 degree. Both are 70 cc chamber. Both ran on a 408. The better flowing heads made 1 more hp and 2 more ft lbs at peak numbers vs peak numbers. Both heads were ran with a FAST 102. Both had cams optimized for the heads and they ran both heads with both cams. But the rectangle port heads made considerably more torque under the curve and therefore a higher average power number, more average power makes the faster car. Also, they would be a lot more fun to drive. When they kept the cam and only swapped the heads and ran head to head with same cam they only saw a peak power diff of 5 hp if I recall correctly but considerably higher tq under the curve with the cathedral port that flowed a lot lower cfm..
Old Oct 9, 2019 | 05:23 PM
00pooterSS's Avatar
All that being said I'd love to see mid lift numbers on the TSP heads vs the TFS. 220 vs 220 or 220 TFS vs even the TSP 225/227
Old Oct 9, 2019 | 05:28 PM
TXsilverado's Avatar
I just installed a set of as cast 257cc ls3 heads and lost 3lbs boost. they are also 6 bolt heads in case i ever decide to upgrade blocks.
something to keep in mind when comparing flow sheets is texas speed flows their heads without a pipe on a 4" flow plate. I want to say trick flow and others flow on larger flow plates with 1 7/8 and 2" exhaust pipes.
Old Oct 9, 2019 | 05:30 PM
00pooterSS's Avatar
And I assume picked up a ton of power. What heads were there before?
The 6 bolt on the TSP's is a nice touch
Old Oct 9, 2019 | 05:32 PM
had stock OEM ls3 heads before. I was mostly after the thicker deck. more flow was just icing on the cake.
Old Oct 9, 2019 | 05:45 PM
00pooterSS's Avatar
It seems like you were surprised by it though..?
Old Oct 9, 2019 | 06:49 PM
Tuskyz28's Avatar
Flow benches are like rear wheel dynos .. no two are the same....
Old Oct 11, 2019 | 01:34 PM
MplSS's Avatar
I have prc 220 as cast on my '98 ls1 sbe, with a Titan 4 cam, ls6 intake, lt's, 9" Moser w/4.11s, monster stage 3, etc. It made 427/391 to the wheels on a Dynojet at Doug Rippie. I've had it to the track once, and it trapped 115.6 with a 20 mph head wind, no traction, and me fiddling with launch and shift points. It sure feels like there's lots more in it.
Old Oct 18, 2019 | 11:24 AM
DietCoke's Avatar
I dislike that TSP makes so many of their castings 6 bolts. I can't use a 6 bolt casting due to clearance reasons so I'm forced to either machine a new head, or look elsewhere.
