F/A 427 PREDATOR ..........550 RWHP daily driver?!?!?!?!? Hi everyone, I just thought I would take a minute to introduce you to our latest package offered here at FASTECH. The package, when complete, is known as the F/A 427 Predator. The Predator Package is available at a couple of levels and can be configured to be anything from a docile 550 RWHP street ready daily driver to an all out race course terror. The base package consists of the following items: 1. C5R based 427 short block assembly. 2. LS6 or AFR Ported castings. - 1 piece stainless steal intake/exhaust valves (2.10/1.607) - T&D shaft mount rockers. 3. Complete air intake system. - FAST LSX 90 mm Intake & 90 mm Throttle Body - Smooth Air Bridge and Belows - VaraRam Cold Air Induction Kit 4. Complete Exhaust system. - Kooks 1 7/8 Primary LT Headers - Choice of Catted or Offroad X Pipe (3”) - Choice of Catback system 5. Clutch or Automatic Transmission Upgrades. Clutch - Ram Clutch Disk and Pressure Place - Fidanza Steel or Aluminum Flywheel - McLeod Adjustable Clutch Master - New GM Slave Cylinder Automatic – Level 4 Automatic Transmission and Converter - Vacuum Controlled Line Pressure Conversion - Stall converter matched to your application 6. Other Available Options - Complete Wilwood Brake System with 13.8” rotors front/rear, 6 piston front calipers, 4 piston rear calipers - Custom rear mini tub will allow installation of 345x30x19’s - Custom wheel and tire fitment options to clear brake and suspension modifications. - Various suspension modifications to suit your application. We completed our first F/A 427 Predator this past week and will have the car on display at our Grand Opening Celebration/Dyno Day Aug 21st. Our intended purpose for this particular Predator was for it to be a true daily driveable supercar , and with 550 rwhp on tap with emissions equipment in place , we exceeded our original goal. This car has every available option associated with the Predator package, with the exception of the AFR cylinder heads . In the true spirt of “too much is never enough” , We will be installing the AFR cylinder heads and also a solid lift cam very shortly and I’ll be sure to let everyone know what kind of gains we see with these additions. I’ll finish with a few pics and a dyno sheet, so that you can get a feel for just how nice this car really is. http://www.ls1camaro.net/freehosting...Submission.jpg http://www.ls1camaro.net/freehosting/Dsc_0042.jpg http://www.ls1camaro.net/freehosting/Dsc_0029.jpg http://www.ls1camaro.net/freehosting...20(Medium).jpg http://www.ls1camaro.net/freehosting/GaryDynoFinal.jpg There is no way I could even come close to describing the amount of time and attention to detail that goes into building a predator in a single post , If you have any technical questions feel free to give me a call and I’ll take the time to walk you through every step if necessary. 972-288-9500 |
So basically are you building a car for purchase? How much would something like this cost? |
I have to know...what does F/A stand for? |
f/a =FAST ASS |
Actually "Freese Autosport" I believe, but it also has the Fighter/Aircraft sorta thing going also :D |
Fast Ass works for me. Post up that dyno sheet. |
Posted :D and yes the F/A stand for Freese Autosport with a Fighter/Aircraft theme. |
ya, I got a question. Who's sheriff Brady? Will ya'll post an et slip for this thing? WG |
Sheriff Brady...as in the Sheriff killed by the Regulators (including Billy the Kid)?? Ya know...he got a 1/2-second drop on ol' Sheriff Brady after he filled the front sight down... :) |
ET slip? Doubt it. This particular car rarely sees the street, much less the strip. It is not driven very hard. It only has about 1700 original miles on it. Look for it an upcoming issue of Corvette Fever magazine. |
Originally Posted by Reckless ET slip? Doubt it. This particular car rarely sees the street, much less the strip. It is not driven very hard. It only has about 1700 original miles on it. Look for it an upcoming issue of Corvette Fever magazine. Now thats a tease |
That seems like a pretty expensive upgrade. Sounds and looks like it will be kick ass! My guess is between $35K and $45K for the upgrade. |
Originally Posted by 99-LS1-SS That seems like a pretty expensive upgrade. Sounds and looks like it will be kick ass! My guess is between $35K and $45K for the upgrade. I don't think it is that high. More along the lines of 26k or something. That's not bad considering you will have a brand new car that is going to be just awsome. |
Have you seen the price of C5R engines? I don't know about the shortblock on it's own, but with that element, I wouldn't be surprised to see this kit exceed the 30k mark. |
he said on ls2.com that the base price was around 23k..... |
Originally Posted by jRaskell Have you seen the price of C5R engines? I don't know about the shortblock on it's own, but with that element, I wouldn't be surprised to see this kit exceed the 30k mark. |
the motor and components alone should be close to 25k if you are talking about the brakes and other stuff, it will be more |
For about 20K i would not hesistate to have this done! But there is a problem I do not have the 20k to do it. God i wish I did that is freakin sweet |
Base is upper 23's. ;) |
Looks extremely cool and should also haul ass with 550 at the wheels as well! Good work and the shop also looks first class from the pics! :drive: |
© 2024 MH Sub I, LLC dba Internet Brands
