LittleBoyBlu99 | 09-02-2004 12:55 PM | MTI's R1 & Stage II R heads??? My car is at MTI waiting to have the R1 cam & Zo6 injectors installed. Ihave the stage 2 R heads with the 2.055 /1.60 valves and was told this combo would work with out flycutting the pistons" but now some at the shop thinks because the duration is 232/236 that it may need this done.The lift is only 575/578" so I am trying to save on the cost of having to pull one of the heads if there's no issue on the clearence . :( If you can help" it would be a big help! :usa: |
