Oil pressure pegged @ 64(99 C5)
Old 09-19-2004, 06:02 PM
7 Second Club
Phil99vette's Avatar
Default Oil pressure pegged @ 64(99 C5)
I started my car up today and noticed the oil pressure guage sweep around as normal and come down to 40 and slowly move to 64psi. This is with the car off. Would a bad sensor cause this?
Old 09-19-2004, 06:19 PM
Under criminal investigation for fraud
Chris@AP-Engineering's Avatar
Sounds like your sensor may have gone bad on you. Double check to make sure also that it did not come undone. Good luck trouble shooting.
Old 09-19-2004, 07:18 PM
7 Second Club
After looking at where the sensor is, its probably bad. I recently had a nitrous explosion and it was right in that vicinity where the carnage took place. Thanks!
Phillip
