Vinci Rocker's Has anyone used Vinci's Rocker's, from Florida. I'm thinking about geting a set of thw 1.79 or 1.89 rockers... I hear good things from Vinci and his boy's. |
Originally Posted by jz06man Has anyone used Vinci's Rocker's, from Florida. I'm thinking about geting a set of thw 1.79 or 1.89 rockers... I hear good things from Vinci and his boy's. --Bill |
Yes you are correct, these are Crane rockers. Does anyone have any info on these. they are supposed, for exsample, start at low lift- 1.79 ratio and then at mid lift revert back to 1.7 ratio to the maximum lift programmed by the Cam. I'm thinking of installing this on a light cam for my Z06, which will have a lift of .551/.551. Any thougths on this. |
had them installed by VHP in the 99 formula. the 1.89 accelerated lift kit. http://www.stealthram.com/99formulatimeslip.html picked up almost a tenth and almost 1 mph. here's some info on the accelerated lift technology. http://www.vincihighperformance.com/...RTSPARENT.HTML here are the dyno sheets. the tq peak is misleading. there was a spike at the beginning. http://www.stealthram.com/familypics.../dyno911hp.jpg http://www.stealthram.com/familypics.../dyno911tq.jpg |
Mrr23, What type of cam did you have with these pulls... The bottom dyno chart showed a huge jump in torque from 328 to 37X something.. Did you change a cam, if so what kind. Could you feel this jump in power with the rockers.. Did these rockers affect you idle or streeability of the car. I'm looking at their 062 cam 210/218 .551/.551 lsa 112... |
let me quote myself on the torque jump
Originally Posted by mrr23 here are the dyno sheets. the tq peak is misleading. there was a spike at the beginning. |
| All times are GMT -5. The time now is 09:54 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
