Second time I've had a rocker arm bolt break off in the head....
Why can't GM make bolts that can hold up to the abuse they see? I broke my first rocker arm bolt off in my head just by driving around town. Everything was torqued properly and rechecked. No problems until about 1000 miles after a cam change. Now I'm in the process of changing a cam on my friend's truck and the bolt broke off while my friend was changing a valve spring. Both have been on the #7 cylinder. It wasn't an error on our part, we made sure both the hole and the bolt were clean before we began. The bolt broke off while the spring was being decompressed too. Someone really needs to make hardened rocker arm bolts.
perhaps if someone gathered the specs and sent them to ARP, along with a consensus(or some sort of petition, anything showing a mass interest) they might look into it. may not be the cheapest of bolts but well worth it.
1 Post
Were you using a lever style tool to remove the springs? If so, those things are notorious for breaking off bolts.
I just stripped one of the rocker bolt holes in my passenger head, so I feel your pain..
I like this idea of making stronger bolts, but you know if they were to put something that cost gm $300, they would yank the cost up another $1000 on the car. I'd rather it be aftermarket.
I would honestly pay as much for ARP rocker arm bolts as their head studs cost if I knew they wouldn't break.
The problem is not usually the bolt breaking it is the threads stripping/or pulling out of the head, a stronger bolt is only going to make that problem worse.
Personally I would rather deal with a broken bolt.......
Local dealer..
Originally Posted by quickWS6
The problem with that is this is his daily driver and I highly doubt any of the dealers around here would have one in stock. But a friend of mine at a junk yard is going to help me out with one.
You'd be surprised. It is in stock at alot of dealerships. I had to look them up locally before.
FWIW: I guarantee if you get a tool like Larrys tool, it'll be a long long time, possibly enver, before you break another one. I broke 2 using the modified lever tool. The tool larry made has been used on over 10 different occasions just in the past 3 months.. It'd be very difficult to damage something with this tool.
Josh
Josh
