Oily intake, heads/intake runners and valves..
1 Post
The pics that I'm including are of my heads and intake.
The car has been blowing blue smoke. I was pretty sure that it was because I didn't seal the rocker bolts..
Now I'm almost certain that I have bad valve seals also, and I definitely need a catch can..
What do you guys think?
http://community.webshots.com/album/201326553mglQMs
That is a lot of oil in the intake. My car started using oil after I installed a cam. And I'm about to replace the heads, so I expect to find a similar situation. Tho I am not blowing blue smoke. That usually indicates your rings are going south. Which would also give you a ton of blow-by that would make for lots of oil coming thru the PCV to the intake.
1 Post
Is there a link or something explaining blowby? I know one of the reasons the heads had oil in them...
But I shouldn't be having blowby issues.. the car only has 35k.
mine looked worse than that when I was changing out my intake believe it or not, I ran seafoam thru it and it smoked like a dog My motor only has 32K on it. it does not smoke blue or otherwise though.
Restricted User
Mike..get some silicone on the rocker bolts and sea foam the intake while its off, as well the TB if its oily too.
How we looking on settling up? Just get ahold of Andrew, I need the help man.
1 Post
Originally Posted by itchygomey98
If you didn't seal the rocker bolts, that's most definitely where some/if not all the problem lies.
Just waiting for all the pieces to get here so that I can get the car back together.
I hoping that the Crane dual spring remover makes things alot easier.
