do I have a cracked head?
Old 10-30-2004, 05:03 PM
the judge's Avatar
Default do I have a cracked head?
ever since i put my tea 5.3 1.5 heads on my 04 gto i have been loosing coolant and is going in the motor every couple of days i pulled heads and had them milled and checked the deck of the block and i am still loosing coolant even after i put new head gaskets please help im getting agravated.
Old 10-30-2004, 05:05 PM
cyphur's Avatar
Have you called TEA? Take some pictures, they will help ppl online help you.
Old 10-30-2004, 06:45 PM
Mirek's Avatar
If your heads are milled your bolts may be bottoming out. This would explain the coolant loss. What bolts are you using ?
Old 10-30-2004, 10:48 PM
6 Second Club Moderator
LASTLS1's Avatar
You could ge the heads pressure tested.
Old 10-31-2004, 05:38 AM
the judge's Avatar
im using arp bolts
Old 10-31-2004, 09:04 AM
Mirek's Avatar
Do a search on those bolts with milled heads there are some problems w/vendors and members. Not saying thats your problem but bottoming out with milled heads and arp bolts has come up before.
Good Luck.
