LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Ideal Air/fuel ratio's (https://ls1tech.com/forums/generation-iii-internal-engine/233235-ideal-air-fuel-ratios.html)
jz06man Oct 30, 2004 10:02 PM
What is an ideal a/f ratio... Mine is currently running about 13-13.2 from 3.3k to the fuel cutoff.. I'm sure this is a safe tune.. What levels can i take this too, and at what point should i begin to worry..
code4 Oct 31, 2004 09:56 AM
I have been told that 12.5 to 12.8 is ideal at WOT.
MNR-0 Nov 1, 2004 09:11 AM
I run mine at 12.1-12.3 at WOT. I have CATS up under the firewall so they like to be kept moist. Too hot and the O2 sensors will be affected, as well as risking a false lean condition.
foff667 Nov 1, 2004 09:15 AM
12.8-13.0 or even slightly leaner on the street is fine for the most part. If your running 13.3 on a dyno t hats a different story.
Ryan02SS Nov 1, 2004 09:20 AM
I'm 12.8-1 at WOT from 2500-6800 rev limiter across the board on the dyno. A tad higher 13.0-1 on the street.
jz06man Nov 1, 2004 09:06 PM
Sorry may a mistake read the file. I am at 13.0-12.8 3300k to fuel cut off...
This ofcource what an a dynojet..
How much leaner can i do without any issues??
© 2026 MH Sub I, LLC dba Internet Brands
