TR 224/224 vs TSP 231/237?
Has anyone checked the power diffeerence between this cam, to me it seems like 231/237 is the obvious choice for power but i was wondering what you guys thought...
!LS1 11 Second Club
The power curve of the TR224 may be better for around town bursts, but the 231/237 will ET and Trap better. Conservatively, there's probably about a peak 15rwhp difference between the two.
SN95 Director
it depends on where your talking about this power. from idle to about 5500 rpm the tr224 properly tuned will out power the tsp231/237. from 5500 on the tsp231 will pull away and net you a ~20rwhp at peak.
all depends on what your application is and what your willing to trade off.
i was just wondering about how they would compare, i kinda knew the 231/237 would outpower the 224/224 in the 1/4 and the low end but was wondering how much, what do you think about the 233/233 torquer compared to the 231/237? being the torquer's lifts are that much smaller?
Lets also bring up the topic of gearing. The TR224 is on the fine line of being undergeared meaning the stock 3.42s are just doing the job. With the 231/237's lazy lobes it would be awful with anything but 4.10 gearing. Unless your going with 4.10s or lower then the TR224 all the way. I also think the 231/237 is only good for 8-15rwhp max over the TR224.
Vertigo, I believe what they are saying is the TR224 will be fine with 3.42s because of the increased lower power compared to the 231, where (I believe) it makes less lowerend power, but pulls in the greater rpms. 5k+
Be very carefull with the larger cams, they can slow you down if you are not set up for it. My car went 11.1@124.8mph all motor with a TSP 225/225 589/589 cam. I later put in a MTI X1 cam 230 227 .591 .571 112 and it slowed me down to 11.6 @ 119 mph. I made more power on the dyno with the larger cam but my 1/4 mile times slowed down.
I have also used the TR224/224 cam--it is a very good all around cam.
The TSP 225/225 589/589 gave me 1mph and .1 in the 1/4 over the TR224 cam.
