Can't decide what cam to get Hey guys I am having a tough time choosing a cam, I am looking at BIG ones being I want a Cam only car because the funds are limited. I want something that lopes really hard and has lots of power and a Nasty idle :devil: . My buddy has a 231/237 on a 112 LSA, sounds very nice but want mine to sound better!!! The car is not a daily driver (thats why funds are limited) so the bigger the better I was thinking something in the high 230s low 240s on a 110 LSA, or if anyone can think of a custom grind would like to keep shift points under 7000 being it is a stock shortblock!! And yes I know I need valvetrain, I am looking into the PP Dual gold spring kit from Speed INC. Hope you guys can help me, thanks in advance Dan |
MS3, G5X3, or the t-rex in that order. |
mti x1 |
Those big cams are nice to a certain extent but you still need LS6 intake, LT's, and heads to breathe. Plus remember with those monster cams spring changes are an annual maintenance item. |
sounds like the trex cam is calling for you. |
LG Juggernaut cam, it lopes HARD. It also works very well with stock heads. You will need an LS6 intake and a full exhaust to see the most from any set up. |
I have Jet-Hot LTs with a Lanes 3" X-Pipe that Dumps before the Axle, I think that should be good for the exhaust system :) As for the LS6 Intake there is one sitting in my house already!! Dan |
If I owned a 6-speed I would go huge like a G5X3; in fact I might even try that on a 114 LSA for my A4. :) I heard a G5X2 112 LSA idle on an A4 and it was wicked. |
I just ordered the Futral Ron Jeremey Cam (aka FM15). It was a toss-up between the G5X2/X3, the T-Rex, or the Ron Jeremey Cam. I think I made the best choice. |
Ordered my Ron Jeremy cam as well. I think I made the right one as well. But if you want a G5X3, I have a new one I need to sell. |
I would wait to see some #'s on the new Futral RJ cam. Futral cams make awesome power, and it wont need to be spun as high as a T-Rex. |
Originally Posted by black_z I would wait to see some #'s on the new Futral RJ cam. Futral cams make awesome power, and it wont need to be spun as high as a T-Rex. edit: that buddy of his is SidewaysOZ....his thread is up near the top with the almost hundred replies ;) |
Call a reputable engine builder and ask them to spec one for your car. Otherwise, you will be guessing. |
Originally Posted by BLKTA If I owned a 6-speed I would go huge like a G5X3; in fact I might even try that on a 114 LSA for my A4. :) I heard a G5X2 112 LSA idle on an A4 and it was wicked. G5X3 on a 112 requires flycutting to be safe, or else I would probably go with that cam. :judge: |
does anyone have the specs on the lg juggernaut cam? |
MTI has just made a new cam. They are putting it in my car right now. I had the X1 cam and this is alot bigger. Talk to David at MTI, he will let you know what it is. I will say this, the new cam they are putting in is sweet as Hell. They had to flycut because I have S2 heads. My car will be ready Tuesday, I will have dyno results then!! And this weekend track results!!Car in Sig!! |
| All times are GMT -5. The time now is 09:10 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
