comp 918's on FMS cam.
Old Nov 22, 2004 | 03:17 PM
98hawk's Avatar
Default comp 918's on FMS cam.
I already have a set of new comp 918 and titanium retainers. Looking to install a F11 or F13 cam. Should I get better springs or will these work.
Old Nov 22, 2004 | 03:31 PM
Scalpel's Avatar
Call Futral.
It's their cam, they know the lobes, lift, etc.
They'd be the best to ask.
It'll save you time instead of waiting on here for a response.
Generally, if you're under 0.600" lift with the 918s you're good to go.
Old Nov 22, 2004 | 04:53 PM
Turo's Avatar
they recommended me the PRC springs to go with the F13
Old Nov 22, 2004 | 11:59 PM
CaptUSA's Avatar
Yep, best just to find out. Both the above posts are correct also.
Old Nov 23, 2004 | 12:10 AM
99BackNBlackZ28's Avatar
That's funny, they recommneded the Manley's for me w/the same exact cam!
Old Nov 23, 2004 | 06:51 AM
PREDATOR-Z's Avatar
918's are fine but duals will give you that extra peace of mind.
FM1-F11-112 FMS Custom Grind Camshaft - 228"/230" .576"/.595" 112LSA - aggressive profile with a 2200-6600 RPM range, fair idle $359.00
On Sale!
FM1-F11-114 FMS Custom Grind Camshaft - 228"/230" .576"/.595" 114LSA - aggressive profile with a 2200-6600 RPM range, fair idle $359.00
On Sale!
FM1-F13-112 FMS Custom Grind Camshaft - 230"/232" .595"/.585" 112LSA - aggressive profile with a 2500-6800 RPM range, rough idle $359.00
On Sale!
FM1-F13-114 FMS Custom Grind Camshaft - 230"/232" .595"/.585" 114LSA - aggressive profile with a 2500-6800 RPM range, rough idle
