Lunati Stealth Cam/LS1 heads/6.0 motor....
Old 11-24-2004, 03:25 PM
Yelo's Avatar
Default Lunati Stealth Cam/LS1 heads/6.0 motor....
How will it idle and drive ???
Before you answer this remember that this combo is in a 5600lb truck with a 4l80, 4:10's, and a stock 2000rpm stall
Tuning isn't an issue....but I need to drive it 140 miles to the place that will tune it so it has to be drivable from the get-go, I'm also very concerned about loosing low-end power....anyone have any idea how this cam will respond in the low-end (~2000-3000rpm)
BTW...the Lunati Stealth Cam specs are: 220º/220º .581/.581 114lsa with no advance ground in.....it's just like the MTI "Stealth I" but with a 1º smaller LSA
Old 11-24-2004, 07:25 PM
someday's Avatar
i think u may want some advance in it, to give u more bottom end, as u really don't need it to scream up past 6000... how about the TR220? i think that has 4* of advance built in... i would go a bit smaller myself, with a split since u don't have headers, maybe a 214/220 on a 113...
Quick Reply: Lunati Stealth Cam/LS1 heads/6.0 motor....
