patriot heads...
Old 11-26-2004, 02:51 AM
redrocketls1's Avatar
Default patriot heads...
okay... lookin on ls1speed.com and i cant tell the difference in the bare and complete heads patriot offers.. if i didn't know any better id think they were all bare, but i readin the dec 04 chevy hipo magazine that stage 2 came with there dual spring titanium retainers ect ect... so basically that would mean the stage 2 patriot heads/cam package that includes chromemoly pushrods would be all id need to install the cam and have ported heads!?!?!! sorry im a lil confused...
but while im posting this, this may be a very old question, but im spraying a 150 shot and i guess im going to go with a 224/228 114lsa cam? or would 112 still work with spray? someone told me i needed 114. anyways.. what compression ratio am i looking for 10to1 or 10.5 to 1 if i wanna run 93 or 95 pump gas??
Old 11-26-2004, 02:58 AM
Mr. Bungle's Avatar
Their heads come complete with everything to install. I have them on my car and love them. I can't answer your question about the cam but i would say someone else could.
Old 11-26-2004, 02:59 AM
cyphur's Avatar
fully assembled heads normally come ready to bolt on.....minus rockers and such.
The cam doesn't need to be on a 114, nitrous just responds better to a somewhat larger LSA. Having an A4 most people run a 114 LSA just for drivability purposes anyhow.
If you want to run 95 octane pump gas, you can run a heck of a lot higher than 10:1 compression, stock is 10.1:1 and the LS6 crate runs a 10.6:1 if I'm not mistaken. More compression = more power if all other things are done correctly.
Old 11-26-2004, 04:38 AM
PREDATOR-Z's Avatar
Under high nitrous cylinder pressures, the less overlap the better so a 114 will respond a tad better over a 112. This is negligeable with 100 shots but becomes more pronounced as you reach 150. Beyond that you need as little overlap as applicably possible.
11:1 has been the general consensus where the LS1 fairs the best, but with nitrous, going higher is better, it just becomes more difficult to tune as detonnation becomes more evident.
Old 11-26-2004, 05:55 AM
Black02SS's Avatar
I ran a 224/224 on a 112 and sprayed it. No problems at all with a 10.8 CR on pump gas. Give Gunnar a call at Patriot or Tom at Speed Inc. Both will be able to help you out.
Old 11-26-2004, 10:27 AM
word.. thanks a lot guys very very helpful.. will prolly go 10.5 cr.
Old 11-26-2004, 11:01 AM
Rays C5's Avatar
Old 11-26-2004, 03:20 PM
family sedan's Avatar
I doubt you will be spraying enough to ever have to worry about a cam's LSA.
