LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Will this setup get me close to the 10's n/a? (https://ls1tech.com/forums/generation-iii-internal-engine/243689-will-setup-get-me-close-10s-n.html)
Drew778 Nov 28, 2004 06:01 PM
Forged 347, AFR 205's, Cam 237/242-.603/.609 and all the mods in sig.
Another thing will this cam be ok for a daily driver?
Thanks
Andrew
David Gordon Nov 28, 2004 06:25 PM
It will not be the best daily driver but it will work. I had a cam simular to that in my last set-up. Made 449 rwhp.
Drew778 Nov 28, 2004 06:51 PM
Thanks, I'm hoping for low 11's high 10's n/a and low 10's with nitrous :)
Drew778 Nov 29, 2004 02:51 AM
Anyone running this setup?
35th SS Nov 29, 2004 03:08 AM
really gettin serious now.good luck lilD.
CAT3 Nov 29, 2004 03:14 AM
I dont think you can run two cams in one LS block, maybe the cobra motor you can? Hmm. Not even sure if you can put that together and get it to run right looking at your track record!
ok j/king over.
I think the cam will be a great daily driver, at least as decent as mine....before its recent lean problems! You should be good for the high tens NA, and then spray your way into the 9s! Glad to see you are finding where you want to go with this POS Andrew. Good luck. When does the block get there?
redrocketls1 Nov 29, 2004 03:15 AM
Thanks
Andrew
wouldn't mind tellin me the dyno #'s u made with tt224 and heads would you?? and alos what shot u were spraing to run 10.8.. i spray a 150 and am looking at h/c packages is why im asking.. thanks :cheers:
Drew778 Nov 29, 2004 09:57 AM
I don't really know the final HP #, we did most of the tuning on the street with a wide band O2.
Last time I dynoed was 1 1/2 -2 years ago, n/a was 390 hp & 380tq and on a 150 shot 513hp & 585 tq.
For the 10.8 run, I sprayed a rich 175 shot :)
Since then I added the EWP and went from a Yank 3000 to a TCI SSF 3500.
© 2026 MH Sub I, LLC dba Internet Brands
