LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   What Rockers with Comp R's (https://ls1tech.com/forums/generation-iii-internal-engine/251225-what-rockers-comp-rs.html)
SmaknaSS Dec 18, 2004 04:07 PM
Best ajustable Rockers with Comp R's?
I was recomended by someone(Dont wanna say who cause I dont wanna start any shit, I just want it fixed) to use Comp R's but found out later after reading many post's on this site that comp R's are not a good choice for my setup. :bang: Anyway, My bad for not reading up enough on them. I wanna buy some ajustable Rockers but wanted to find out what justable rockers do you all think would be a good choice for my setup? I would rather have stronger rockers than stock but at the same time lighter too. My valve train setup consist of a TR224 cam,Comp R's lifters,7.4 inch push rods,Stock rocker's for now,And AFR 205's. Please help me out guy's, Thanx in advance.
SmaknaSS Dec 18, 2004 05:21 PM
Anyone? Pleassssssse?
SmaknaSS Dec 18, 2004 09:08 PM
tttop
SAM98WS6 Dec 18, 2004 09:31 PM
Comp Pro Magnum (1.75) is what I have...work perfect. Check your pushrod length regardless of what rocker you choose.
Set your valvetrain .008-.010" after zero lash...about 1/5 turn if you use them. Soak/scrub the lifters and rockers in mineral spirits to get rid of the cosmolene..then soak in oil for a few hours before install.
Mike K. Dec 19, 2004 02:51 AM
I say go back to the stock lifters and use whatever rockers you want. If it was me I would use the stockers with the comp r's. I had comp r's and yella terras and all I'm gonna say is that is not a good combo.
SmaknaSS Dec 20, 2004 06:53 PM
Thanx for the reply guy's.
Beast96Z Dec 20, 2004 10:21 PM
Morel lifters are the shit. They'd be cheaper than new rockers, but expensive for lifters.($500) No pre-load problems with them, but as with any set-up, I'd set-up the valvetrain for the pre-load you want.
zamboxl Dec 21, 2004 10:17 AM
well you already got comp R's lifters so just go with their adjustable pro magnum rockers, or any other adjustable rockers.
Cstraub Dec 21, 2004 11:44 AM
Jesel shafts and be done with it.
Chris
SmaknaSS Dec 21, 2004 06:13 PM
Ditto on that.
© 2026 MH Sub I, LLC dba Internet Brands
