228/232 cam NA...What heads?
Would the AFR 205s work best? With stock heads, 228/232 .588/.581 113 and mods in the sig I dynoed 385hp/421 tq and Im looking for 420+ hp NA. Is that my best option for heads? Any other affordable heads out there that will yeild those results?
What compression ratio do you want for a NA motor? forced induction?
SN95 Director
Originally Posted by Black8Banger
TC was unlocked...darn thing never would lock up on the dyno. Say I dont make the numbers on the dyno. With my current setup on stock heads (385/421) I ran 11.6 @ 117 with a 1.67 60' and 3545 RW are 10s possible with those heads and 3300-3400 RW?
i'd worry less about an arbitrary hp number and more on dialing in your setup; suspension, tires, ect. i think you'll need a bigger stall as well.
