LQ4,LQ9 what is different? Pistons, heads?
I want to know if there is a cyl. head comb. chamber volume difference and is piston different? In other words how is the compression changed between these two 6.0 motors? TIA
Originally Posted by Jason99T/A
Correct, the LQ4 has a very slight dish piston to lower the compression. The LQ9 is a true flat top.
Jason
Jason
TIA
I can shift faster than you.
The 317 castings are the same on both motors. The difference in compression ratio is taken care of with the pistons.
From what I have seen, a max ported 6.0l vs. max ported LS6: they share very similar low/mid lift #s (6.0l slightly better), but the LS6 still flows better up top (past .600+). These differences could be just due to the head porter/port shape, though.
