should I wait until after the power tour for the cam swap
I bought a 232 234 .595 .598 112lsa cam and was wondering if i should wait until after the power tour to swap it, what kind of gas milage should i expect, what kind of wear and tear will it create if any, i will be doing the long haul. the motor will be stock except the cam. i have a gm hot cam in it now
Change those springs when you put the cam in or you'll be on the side of the road. Other than that you are good to go. As far as gas mileage goes...just listen to that lope at idle and you won't care about mileage.
