what is the compression ratio with AFR's with the 205's what does it change the CR to? |
I believe it is about 10.28 with the stock gasket. |
CR Info.... Guys... AFR 205 66 cc Stock LS1 head 67 cc (AFR SLIGHTLY raises CR) Stock LS6 head 65 cc (AFR SLIGHTLY lowers CR) I think "Lady Redhawk's" calculation is spot on with a stock GM head gasket. Thanks, Tony M. |
Originally Posted by Tony Mamo @ AFR Guys... AFR 205 66 cc Stock LS1 head 67 cc (AFR SLIGHTLY raises CR) Stock LS6 head 65 cc (AFR SLIGHTLY lowers CR) I think "Lady Redhawk's" calculation is spot on with a stock GM head gasket. Thanks, Tony M. I talked to a member of the AFR sales staff and he said that AFR wouldn't mill them past 60 CC's. Was just hoping to get your input. Floyd. |
AFR offers milling as an option (they also offer hollow stem valves and 921 springs). They recommend 59cc heads with a 347 for 11:1. David |
where is the cheapest place to get afrs from? |
Originally Posted by DavidNJ AFR offers milling as an option (they also offer hollow stem valves and 921 springs). They recommend 59cc heads with a 347 for 11:1. David |
i dont know whatever kind i can use to get best PV clearance |
anyone know what the best pricing on these is? |
well i haven't checked every sponsors pricing on these but the ones i have all are priced at $2181.99 ... unless there's some kind of group buy or special i think everyone is sellin them for that price |
is that with valves? i gotta get the valves too, futral was 2250 with valves |
AFR 205cc LS1 Cylinder Heads with 66cc chamber assembled with 2.02" / 1.60" Valves, dual coil valve springs(.600" max lift), and titanium retainers. = $2181.99 hope that answers your question ;) |
yes sir, thank you, where did you get that info from, which vendor |
that was a copy and paste from thunder racing's website (www.thunderracing.com) but you can find it for that price also at speed inc (www.ls1speed.com) or texas speed (www.texas-speed.com) ... but you'll get the best deal from texas speed since they sell it for the same price and have free shipping ... here's a direct link, http://www.texas-speed.com/item_deta...ProductID=1257 |
awesome, thanks |
| All times are GMT -5. The time now is 06:20 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
