Haven't started the car in a couple months.... I haven't started my car in a couple months and I was wondering if I should disconnect the coil packs and just turn the car over without firing to pump some oil through it? If so do I need to disconnect the injectors also, and how so? It's also pretty cold here (highs in 30's) but I want to start the car just to run it for a bit since I haven't in so long. Any other recommendations? Thanks. |
Check the oil. Disconnect the coil pack connectors, remove the fuel pump fuse. Crank over for 10 seconds or so. Reinstall everyting, warm up. :chug: |
| All times are GMT -5. The time now is 12:21 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
