What Rocker will go on 98 head w/out modification? Folks, I am looking for an aftermarker 1.8 roller rocker for my 98 heads without modification. So far I know that the HS cause valve cover mod. So what about: Jessel Yella Terra Comp SLP Thanks in advance and pictures of the modifications would be greatly appreiated. blackramair@neb.rr.com Later Z |
Not much will fit the 98 heads without some grinding. The SLP's will fit since they look like stock. I tried the Harland Sharp Rockers and the hit the valve covers and the head had to be grinded. I ended up putting the stock rockers back on. |
Comp 1.85 pro magnums. |
Originally Posted by z-ya Comp 1.85 pro magnums. Out of the ones mentionned above, it is SLP |
© 2024 MH Sub I, LLC dba Internet Brands
