(pic) What's are these stuck to the oil drain magnet?
I just got back from a friends. He said you better get over here and bring your camera. It's an LS1 motor. What' the deal here. Roller lifter needle bearings? Internally everything is stock. What the hell would cause this?
Give him some feedback on what next to do please.
Most likely they're needle bearings from the rockers. Pull the valve covers and look at all the rockers. You might want to try an account for all the needle bearings just for piece of mind. I dont recall how many are used per rocker, but a search should set you straight.
We found 24 so far. It sure would be nice to get a count of what they start out with and find all them bastards. Red Line 10W30 since the first oil change I am told.
