Cylinder Pressure Observation On 2 T/R Cams
Old 02-01-2005, 05:29 PM
2xLS1's Avatar
Default Cylinder Pressure Observation On 2 T/R Cams
I just switched out a TR220-114 with a TR224-112 on a car. Just out of curiosity, I ran a compression test on one cylinder before and after the swap. With the 220 cam i had 192 psi and with the 224 cam i had 210 psi. Tests performed immediately before and after the swap. Conditions for both tests were identical. Same cylinder, same engine temp (cold) throttle body held wide open and same cranking duration. I would have thought with the 224 on a 112 lsa and more overlap, the cylinder pressure would have been less than the 220 on a 114. Anyone want to explain why?
Old 02-01-2005, 08:00 PM
SSean's Avatar
Your getting more air into the cilynder to compress?
Old 02-01-2005, 09:17 PM
Moderator
JNorris's Avatar
I do not have an answer for you but your numbers seem to be in line with my TR224 114 numbers. FWIW the TR224 112 has 0* overlap and the 220 114 has -8*(none)
Cyl--PSI
1----210
3----220
5----215
7----215
2----215
4----220
6----220
8----210
Old 02-02-2005, 05:13 PM
Viper's Avatar
My TR224 #'s on the 112 were all above 215. FWIW.
Old 02-02-2005, 10:43 PM
JS
JS's Avatar
I had about 230 in EVERY hole running the TR224 114...
This cam rocks
Oh and this was the motor someone told me had 3 dead holes.
It leak downed at less than 3% in EVERY HOLE too,plus it ran the times in the sig.
Yep that sure is a bad engine,Dave
