GM 6.0L Head Gasket ? What is the Compressed Head Gasket Thickness of a GM 6.0L Multi-Layer Steel LS1 Cylinder Head Gasket? |
i believe the 6.0 uses a .060 and the 5.7's use a .052-.054 |
Something is not adding up right between the LQ4 and LQ9. Are the heads differant on them also? I thought the only differance was the pistons. 4.00" bore 3.622" stroke 71.06cc chamber .060 gasket 4.100" gasket bore -.008 deck height -6.6cc piston 9.38:1 |
OK I feal stupid the LQ4 has 9.4:1 I thought it had 9.1 and things just were not adding up. Give the new numbers this is what I have. 4.00" bore 3.622" stroke 61.15cc chamber .060 gasket 4.100" gasket bore -.008 deck height -6.6cc dish Giveing me a 10.4:1 CR but I have plenty of room for milling. Next question is how much can I mill the heads before I have issues with the intake manifold. I think I can only mil it .030 if so I think that will bring my CR up to 11.3:1 Can I mill it amy more than that? |
© 2024 MH Sub I, LLC dba Internet Brands
