which hose to pull top end cleaner through??
Old Feb 20, 2005 | 03:57 PM
Raise's Avatar
Default which hose to pull top end cleaner through??
im putting some top end cleaner thru my motor b4 my h/c swap this week. which hose is recommended to feed the cleaner through?
Old Feb 20, 2005 | 07:12 PM
NastySSoo's Avatar
The one that goes directly into the side of the intake manifold neck. Good luck!
Old Feb 20, 2005 | 09:42 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
I use the GM aerosol type, and spray it right down the TB at idle.
With the liquid, do as said above.
Old Feb 21, 2005 | 08:13 AM
Raise's Avatar
i see a hose running from the passenger side of the throttle body to the passenger side of the intake manifold. should i pull the intake end of this hose and suck the cleaner in thru that?
Old Feb 21, 2005 | 01:50 PM
Raise's Avatar
ttt......
Old Feb 21, 2005 | 04:09 PM
Another_User's Avatar
That is what I did. Go ahead and try and stall your car out with that crap when the can starts to get low. I couldn't do it...looking back on it, I should have pulled the plug on the IAC so it would stop trying to compensate and it would have worked. If it doesn't stall, just turn the car off real quick.
Old Feb 21, 2005 | 04:15 PM
Raise's Avatar
yeah but what hose exactly should i use?
Old Feb 21, 2005 | 04:19 PM
NastySSoo's Avatar
Either will work, I use the one on the "neck" of the "manifold", not the throttlebody. Ive always used the aerosol since its just easier.
Paul
Old Feb 21, 2005 | 04:52 PM
Raise's Avatar
so which end of the hose do u pull off to suck the cleaner thru?
