breakin period until dyno time for h/c install???
Old 03-03-2005, 10:09 AM
Raise's Avatar
Default breakin period until dyno time for h/c install???
i just installed my mti stage 2 heads and stealth cam this weekend. i was told to baby it for 500 miles (or close to it). the problem is i need to get it tuned pretty soon in case im runnin lean or anything. any suggestions or opinions on break in period til my dyno/tune?
Old 03-03-2005, 10:11 AM
LSUxBlake's Avatar
You dont need 500 miles, just drive it around town with dino oil in it for like 20-30 miles, change the oil to synthetic, then run it.
Old 03-03-2005, 10:23 AM
LS1TECH Sponsor
Steve Burger's Avatar
Break it in like ya stole it.
Old 03-03-2005, 10:32 AM
SmaknaSS's Avatar
Dont forget to heat cycle the new springs on your heads.
Old 03-03-2005, 10:56 AM
VSGLS1's Avatar
500+ miles maybe for a new bottom end...
Run the dyno oil in it for 20+ minutes, drain, replace with synthetic and it should be good to go.
Old 03-03-2005, 11:02 AM
Raise's Avatar
we already did the heat cycle and top end cleaner with regular oil, then switched to synthetic. so now that i have synthetic and the springs have been heat cycled, what now?
Old 03-03-2005, 11:06 AM
Ryan02SS's Avatar
If you have a new longblock I would break it in for 500-1000 miles before taking it to high rpms on the dyno. Since you just replaced your heads and have allready heat cycled the springs, take her to the dyno.
Old 03-03-2005, 11:12 AM
Restricted User
2001 Pewter WS6's Avatar
Go dyno it... I've swapped heads and cam drove it just to make sure all was well then went straight to the track. You only need to heat cycle the springs. Do you think people with race cars drive them for 50-100 mile before they race them???
