LS1 vs. Cobra motor?
Old 03-06-2005, 02:24 PM
DravenMyers's Avatar
Originally Posted by 90ZR1
Unfortunetly I hangout and am friends with a majority of Ford guys. We have gotten into the debate on which motor is better... LS1 or the new Cobra motor... I jus get frustarated because I do not have the strongest points. I do know things about the LS1 but i have a LT5. I am a GM man for sure and would like to find out some things about the LS1....
Is it a better bang for the buck?
Can it hold more horsepower on stock bottom end?
You throw a procharger on an LS1, or on a Cobra, which is better?
I know this is also a useless debate, but they really get agrivated when I say things. I do love fords as well, but you know when it comes down to 1v1 we gotta choose GM. I just want a better argument, any other reasons you have would be great.
TIA
Dont forget the new Z06 has all ready skined the viper and I am shure it will also clown on the the gt40
Old 03-06-2005, 02:34 PM
Wnts2Go10O's Avatar
Originally Posted by PREDATOR-Z
Don't laugh, till this day, modded 5.0's are fearsome. I was refering to the pre 95 pony 5.0 VS post 5.0's until the appearance of the 4.6.
then explain y those 5.0s wth h/c/i wont run s mid 12's..
Old 03-06-2005, 02:38 PM
Wnts2Go10O's Avatar
those cobras are blown and the ls1 still whoops it and the ls1 is n/a. the ls1 is more bang for the buck.. its so massively expensive to mod a cobra motor. also the cobra motors are physically massive, i think someone borught up in a different thread that they were as big as the 429 boss motors.
Old 03-06-2005, 02:49 PM
zamboxl's Avatar
ok i love the ls1 but we all know that a stock ls1 won't hang with a stock 03-04 cobra. I think we gettign a little ahead of our selves here. Yes a cam head ls1 will make a **** load of power, for far less money that it will cost to put heads and cams on the ford. But then again they don't need heads and cams they'll just simple turn up the boost. With unlimited money, the ls1 is better, easier to work on lighter and like everyone knows there is no replacement for displacement.
Old 03-06-2005, 02:55 PM
Frosty's Avatar
Yeah no kidding. Granted we're all GM guys here but Jesus...let's ditch all the biased feelings aside...the Cobra is still a respectable car.
Old 03-06-2005, 03:16 PM
PREDATOR-Z's Avatar
LOL. you guys crack me up. Now i'm a ******* for respecting where respect is due.
And 5.0's that are only capable of 12's??? Now that is reaaaaly funny.
I'm 1/2 way across the world and there are 2 guys here with turbo 5.0's into 9's (And believe me when I tell you that the only track we have here reaaaaly sucks)
You guys should get out more often.
Bottom line guys, never underestimate anything or anyone and there is always someone faster than you and NO, it is not always an LS1.
Old 03-06-2005, 03:33 PM
nspr8td lt1's Avatar
Originally Posted by jrp
well define "better". are we talking stock for stock, modded vs modded, ulimate potential, ect.
4.6 DOHC vs 5.7 OHC, there not really comparable in hindsight.
the damndest thing just happened, i was installing my cam and for some reason it was in the block.
Old 03-06-2005, 04:09 PM
jrp
SN95 Director
jrp's Avatar
eh, you knew it was a typo
Old 03-06-2005, 05:53 PM
but ofcourse
Old 03-06-2005, 05:59 PM
Frosty's Avatar
I still want you to back up your statement that Ford detuned the 302 due to insurance reasons
Fact is you're talking out your ***.
Old 03-06-2005, 09:14 PM
Mike98WS6's Avatar
Both engines are great in thier own way. The LS1 is more flexiable though less complex to work on.
Old 03-06-2005, 09:39 PM
  #32
Raise's Avatar
i hear ya man...u make some good points. i think i got a lil carried away back there anyway, im not a ford hater, i just love to jump into these conversations and talk **** for the LS1. im just a nut i like the new cobras...theyre pretty bad....but if were gonna break down motor for motor...theres no contest....cuz ive seen what the 4.6 can (can't) do
Old 03-06-2005, 11:02 PM
  #33
PREDATOR-Z's Avatar
Well, since you're flaming, I'll use the American way to respond and ask you to prove that what I said is wrong, if not take it for what it is worth or file it in bin 13.
Old 03-06-2005, 11:19 PM
  #34
Wnts2Go10O's Avatar
are they stock blocks? ...kind of doubt it, considering on boost those blocks tend to split down the lifter valley. a STREETABLE 5.0 is crap..
Old 03-06-2005, 11:23 PM
  #35
Wnts2Go10O's Avatar
ok, then lets go on efurther, make it truely even. add a blower of the same type and run the same amount of boost and tell me what happens then. ill give u haaveing a blower stock will be a whole new class so lets put the ls1 f-bods with the dohc mach1's
  #36
2000KCTA's Avatar
Face it though. The 05 Rousch Mustang for 25K at the dealership is a hell of a price for a brand new car with the potential that it has.
Old 03-07-2005, 01:04 AM
  #37
PREDATOR-Z's Avatar
You are comparing a 5.7 L with a 4.6 L, like I said above I've seen 351 Boss ponys and they were rated at 320 and that was back in the late 90's when LT1's were making 285.
Why do you think I own a LS1? But i can't deny that the new 4.6 makes 300hp either.
Old 03-07-2005, 01:29 AM
  #38
1 BLOWN V8's Avatar
Well here is one you can use. One very bad flaws on the 03-04 Cobra and this is fact. They installed cheaper pistons to help save cost and also put teflon coating on them to reduce piston slap on cold start ups and help on movement. Bad thing is it heats up easy and can melt causing damage and ruining the block. Cobras are starting to have problems with #7 and #8 pistons. How do I know it also happened to me. I had 18,000 miles and the motor went bye-bye. As long as you keep the stock pulley you are ok. I went with the 2.93 lightning pulley which is about 4 psi more of boost. If you go into SVTPERFORMANCE there is a few that already have had this problem.
Also why is it in 03 they built over 13,000 but in 04 they only built over 6,000 and alot of them sat on the lots and the dealerships had a hell of a time getting rid of them.
Also note: It went in for 2 axle replacements, throw out bearing, new rack and pinion and then the motor. Then I sold it.
also I never ran any slicks or drag radials either.
Just keep watching they will keep having problems. Even some of the early models ligtnings are having problems with blowing out the spark plugs.
Old 03-07-2005, 01:58 AM
  #39
buffman's Avatar
So they detuned a 245hp motor to what? 220 for insurance reasons?
That's what they want you to think. Ford was just jealous because GM's Big-Body LT1 cars were beating up on all those slow 5.0s and LT1 F-bodies were just rapping them
Matt
Old 03-07-2005, 05:49 AM
  #40
Frosty's Avatar
I'm not flaming at all. I'm just laughing at a really factless comment you made.
Quick Reply: LS1 vs. Cobra motor?
