LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Forged Piston's (https://ls1tech.com/forums/generation-iii-internal-engine/290757-forged-pistons.html)
HellRaiser Mar 15, 2005 07:55 PM
Forged Piston's
This might sound stupid but I was wondering if it's possible to put in a set piston's without doing anything else to the block. Like machine work or what not. Say forged piston's and ARP rod bolts?
c5jim Mar 15, 2005 09:18 PM
The answer is no. !!!! I just finished a stock Mahle piston to a Forged Mahle piston last week. A stock (M) piston weighs 434 grams and a forged (M) piston is 382 grams . That is 14.86 ozs that has to be removed off of the crank bobs. I had my whole assembly balanced and they drilled the crank bobs to offset the weight difference.
C5-JIM
CAT3 Mar 15, 2005 10:12 PM
There are ppl that have done it, not sure on their success or problems. s far as balancing it out, the factory crank probably needed to be balanced anyway, I dont see why you take off crank weight due to piston weight changing, unless the stock rotating assemble was off balance.
© 2026 MH Sub I, LLC dba Internet Brands
