LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   H/C Upgrade - Driver's side very lean (https://ls1tech.com/forums/generation-iii-internal-engine/294004-h-c-upgrade-drivers-side-very-lean.html)
C5X2C Mar 22, 2005 10:13 AM
The saga continues!
https://ls1tech.com/forums/pcm-diagnostics-tuning/290669-open-loop-required.html
Why would just the driver's side run lean, constantly correcting by adding fuel and making the car run like crap?
Recent H/C upgrade:
AFR 205 milled .024
224/228 114 LSA
LGM LT with random cats
FAST 78mm Intake
30lb Fuel Injectors
LS6 ported Oil pump
Performance Dampner
We have replaced the O2s and 2 coil packs. No, I don't think the L/R are crossed. The 2001 C5 only has 37k miles.
A smoke test revealed no leaks on the intake side. I guess I am forced once again to diagnose my car's problem after getting it back from the shop. My mechanic is blaming the LGM LTs and suggests replacing them with Kooks.
:confused:
I could really use some help!
white2001s10 Mar 22, 2005 10:39 AM
Either a bad O2 on that side, or it's just not getting/staying hot enough to read correctly.
Search for posts about O2's and long-tube headers.
C5X2C Mar 22, 2005 01:50 PM
Perhaps a weak injector? That should be an easy thing to swap and diagnose!
white2001s10 Mar 22, 2005 01:55 PM
very unlikely
C5X2C Mar 22, 2005 02:00 PM
Why is that?
white2001s10 Mar 22, 2005 02:06 PM
Why is that?
computer adjustments are based on O2 output only, and not actual flow rates. If an injector was down, it would adjust once and reach equalibrium to get the proper O2 output.
If for some reason you're convinced it's an injector problem, then swap sides with the injectors and see if your problem follows. it would only take a few minutes.
© 2026 MH Sub I, LLC dba Internet Brands
