which cam G1 113lsa or G1 on 115lsa
ive been talking to MTI about what would be the best cam for my app, we came to the conclusion that it defintly will be the G1 but he also said that if i plan on driving this car as a DD then i should go on a 115lsa. Other than the idle are there any other real differences between the 2? Ive also heard that the higher the lsa the farther the powerband is pushed back, is that true? Also how rough would the idle be on the 113lsa? Would it be totally unDD'able? BTW specs are G1 228/232 .588/.575 113lsa
go with the 113, it shouldn't be too bad especially since you're an M6. i drive a 110lsa in a A4, and it's no problem. i used to DD it but gas sucked so i don't DD it anymore. That's just my opinion tho.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
