People running BIG cams........inside
Old 04-18-2005, 03:40 PM
tomulrich's Avatar
Default People running BIG cams........inside
Please post specs on your BIG cam (240+ duration) you are running. Also post any issues you may have had with idle.....specifically surging.
I would also like to know what your manifold pressure is at at idle (RPM)
Thanks for the input. Trying to diagnose a problem.
tom Ulrich
Old 04-18-2005, 04:15 PM
Adrenaline_Z's Avatar
Comp Cams 292H-10
Intake/Exhaust: 292 degrees @ 0.006"
Intake/Exhaust: 244 degrees @ 0.050"
(all specs @ 0.050")
IVO: 16 BTDC
IVC: 48 ABDC
EVO: 56 BBDC
EVC: 8 ATDC
Overlap: 24 degrees
Intake Centerline: 106 degrees
LSA: 110 degrees
Manifold pressure @ 800 RPM (200 ft. elevation): 6 in./hg.
Cons:
No assist for brakes. Very choppy idle. Low RPM power is weak (*until about 2000 RPM).
Keep in mind this is not an LS1 engine, but certain characteristics will apply.
Hopefully it will spark an idea to help you out.
Old 04-18-2005, 04:28 PM
tomulrich's Avatar
Thanks adrenaline........everyone please post same specs........
My cam is a 250/256 113 lobe seperation.
My vacuum is 8in./hg
I am being told that this may be the cause of my surge.....I have a 427ci motor.....
Tried everything...and 2 tuners tried as well.......still real bad surge
Old 04-19-2005, 06:30 AM
SAM98WS6's Avatar
Dont know the vacuum but I can check it.
Surge at 2000rpms only...just have to stay out of that rpm...which is tough...
VERY choppy idle
Old 04-19-2005, 09:33 AM
blacktransam's Avatar
yeah i'll have to check vacuum.. i know my brakes only give me about one soft step.. but my cam in my sig and its in a 346..
Old 04-19-2005, 11:11 AM
Cal
Cal's Avatar
Any time you have a cam with 240+ degrees duration you're going to get some surging and bucking, and I don't think there is any way you can tune it out. Smaller LSA's make it worse also. Mine runs rough and surges/bucks at any rpm less than 2000. At first I hated it and tried to tune it out, but I'm pretty much used to it now.
Old 04-19-2005, 11:17 AM
BADSZ28's Avatar
Cal: are you cam only?
Old 04-19-2005, 11:19 AM
Cal
Cal's Avatar
Home ported heads with stock valves and stock compression ratio (heads not milled.)
