i need cam help!! i cant get the damn crank pulley bolt off.. ive been tryin for over an hr.. with air and everything.. still wont come off.. any suggestions.. let me know.. even call me i dont care i want to get this in now 602-791-4082 jason.. thxs for any help!! |
You are using a large three-jaw puller, right? It helps if you drill 1/16" into the center of the bolt head to give the puller a way to stay centered. |
you did lock the flywheel right? |
no.. we cant get the bolt off to get the pulley off.. 2 of us cant get it off |
hey man i just finished getting that damn bolt off about 30 minutes ago.... took me for fucking ever...... i actually took my I pipe off of my car and thru it over the breaker bar.. locked the flex plate in TWO places and literally used a 5 ft extension of pipe and basically jumped up in the air and grabbed onto the end and prayed about 3 times lmao.... oh man, just wait till u install the pully puller, took me 30 minutes to realize it went inside the pulley not outside... DOH! |
I just called you and your phone cut off. Is it a man. or auto? Is the crank turning when you try too break the bolt loose. |
Man I don't know why you guys always want to do this the hard way; a good impact gun or just laying the breaker bar over the frame rail and hitting the starter will break that bolt loose in a microsecond. |
© 2024 MH Sub I, LLC dba Internet Brands
