Biggest Valve on 4.030" Bore
Guys, what is the biggest valve that you can fit on a 4.030" bore with ls1/ls6/AFR/All Pro heads? This is assuming stock valve centerlines (I want to use my current shaft rockers).
Thanks guys. Brent, I'm assuming you guys stick with the 2.08's because of the shrouding. Can you get enough air through a 2.08 opening to feed a 408 at around 8000rpm?
Originally Posted by BrentB@TEA
Your assumption is correct. I would hope so if not we didn't do our job
Hey Brent, are you guys planning on running any programs in the All Pro Heads. I understand there is enough material to almost get 300 ccs out of the intake port. Not saying I need them that big but maybe the bigger ports (260cc ish-280cc ish) would be beneficial to a max effor n/a effort with a big solid roller.
